Hi!
Is it possible to dissolve a super glue joint? I super glued my pearl inlay because it broke but I need to redo that.
/Haggis
Superglue
Re: Superglue
I haven´t glued the inlay to the guitar....just glued the pieces back together.Haggis wrote:Hi!
/Haggis
Re: Superglue
Acetone will do the trick, even some finger nail polish removers will work if "oil free".
Re: Superglue
Doesn't lacquer thinner remove CA as well? Since this is a piece of pearl, you can sit it in a bath of lacquer thinner or acetone and let the solvent do the work. Then come back after a cup of coffee and voila! Your work has come unglued!
Re: Superglue
I´ve put it in a solvent and I´ll leave it there over night. I read that it might take 12 h if the super glue is hardened.....and I glued it together a month ago or so.
thanks for the replies
häggis
häggis
Re: Superglue
Still in one piece....
I used lock tite 401. I´ll try aceton instead....
