Scale
Scale
Post by Dave Bagwill » Fri Jan 04, 2013 1:58 pm
l' m laying out a non- standard scale fretboard. I have done the calculations for the fret spacing and need to know the acceptable accuracy. Is it .x or .xxx in inches? If I use mm is it .mm or attempt even closer tolerances?
Re: Scale
Post by Tim Benware » Fri Jan 04, 2013 2:18 pm
I calculate and measure mine out to .xxx but not sure exactly how close I get when cutting. Haven't noticed any glaring issues.
Re: Scale
Post by Dave Bagwill » Fri Jan 04, 2013 2:29 pm
Thanks Tim, I think for all practical purposes trying for .xxx and hitting .xx should work. Not having a cnc machine, anyway....poor me. :-)
Re: Scale
Post by Dave Bagwill » Fri Jan 04, 2013 4:26 pm
What sort of measuring device do you use, T?
Re: Scale
Post by Tim Benware » Fri Jan 04, 2013 5:32 pm
Digital calipers but don't go from one to the next, take each measurement from the nut until 4th (I think), then 4th to 11th finally 11th to 20th.
Bob Matthews
Re: Scale
Post by Bob Matthews » Fri Jan 04, 2013 5:36 pm
For non standard scales I always use 'W Fret' which is downloadable from MIMF http://www.mimf.com/phpbb/viewtopic.php?f=32&t=921 Print it out full size, stick it to your fretboard and always saw to one side of the lines rather than the centres.
Bob
Re: Scale
Post by Dave Bagwill » Fri Jan 04, 2013 5:41 pm
Thanks to both of you. I do notice that Incra sells a precision rule that allows marking to the 1/4 mm range on a 300mm rule. If I'm not mistaken, that means a possible error of .125mm, which = .004" at each fret. That should be close enough, yes? So I could always go that route, I suppose. I'll try your suggestions first.
