I am building a Dreadnaught out of cherry and when I started to attach the dovetail neck I found that my neck block was not centered on the top, it is off about 3/16" or so. Is there anything I can do to help this problem or just trask it and start on another one.
Thanks
Chuck 1945
Neck Block off location
Re: Neck Block off location
Welcome Chuck,
Pictures would be helpful --- off 3/16" in what regard --center, up, down, angle?
It is off of center line of the guitar top, sorry no pics.
Chuck 1945
Chuck 1945
How does the neck fit otherwise? Is it off center along the length of the center line (moved over 3/16") or does the neck joint throw the finger-board center line off center angled toward the bridge location?
You can even use cell phone pictures. Actually without seeing the situation and how things fit and line up -- anything said here is just a guess.
Exaggerated pic - but is the neck moved over like the red, or angled like the blue?
- guitar_body_1024.jpg (40.5 KiB) Viewed 1445 times
I am very new to this forum thing so forgive me if I don't get the right person answered. The person who sent the diagram of the guitar, thanks and the problem is the same as the red rectangle. I worked on it this afternoon and I moved the neck over and filled the void in the other side, hope it works, if not I guess it was fire wood before i started. Thanks again.
Chuck 1945
Chuck 1945
You are welcome to the forum Chuck! Most problems can be fixed by the collective wisdom of these guys. We welcome your questions and want to help.
