top rim angle question
Paul C
Post by Paul C » Sat Oct 06, 2012 6:30 pm
when using megamold does kerfing always go on first before shaping top angle?
Re: top rim angle question
Post by Dave Bagwill » Sat Oct 06, 2012 6:52 pm
Yessiree. That way whatever you do to the rim you do to the kerfing, they stay in sync.
Post by ken cierp » Sat Oct 06, 2012 6:54 pm
The rim with blocks and kerfing is to be treated as a unit. So yes the kerfing needs to be installed, there is no reason or advantage to "fine" profile just the side material -- the top surface of the rim assembly is suposed to be flat sanded as described here:
http://www.kennethmichaelguitars.com/ri ... angle.html
before the sloping operation takes place.
Paul C
Post by Paul C » Sat Oct 06, 2012 7:11 pm
thanx guys just wanna be sure. appreciate the quick response.
Paul C
Post by Paul C » Fri Oct 12, 2012 2:26 pm
I just finished sloping the rim top following my megamold instructions. Im pretty sure it went well. Now a question. When i set my 6 inch flat ruler on edge across the center of rim next to the neck block with the 3 in mark on center should that area be flat as well in that 6 inches? It is not at this time. there is a 64th rock end to end. iI hope the question is not confusing.
Post by Dave Bagwill » Fri Oct 12, 2012 2:33 pm
Personally, a 1/64" rock would trouble me not at all. It will not affect stability or playability nor will it be noticed visually.
1/4" would be a different story. Sounds like you've done a good job so far.
Post by ken cierp » Fri Oct 12, 2012 2:41 pm
Take the very large sanding stick/block you made to level the rim and kerfing and gently rub it across the upper bout and the neck block in the questionable area. Seems you created a tiny dome. A couple of strokes and it will be sloped and perfectly flat do not change the angle. Pictures would be great when asking questions -- they are a real help to responders.
