back braces
back braces
Can I use my 15' radius bar to shape my back braces?
Re: back braces
Yes, if it's radiused the length of the bar.
Re: back braces
So my back will end up being radiused 15' length and width?
Re: back braces
You would need to profile or radius the the rims for the back to have a 15' radius lengthwise. The braces can hold the radius widthwise.
Re: back braces
Ditto John
Braces are not supposed to be radiused across the width that would ruin the glue joint you'd simply be rounding it over and there is no way you'd be able to bend the back plate to match -- thus gaps. The glue surface is perpendicular to the brace contour.
Here's the simple tool for maintaining perpendicular
Re: back braces
This tool was developed to make accurate machining of braces quick and easy!
http://www.kennethmichaelguitars.com/bracefixture.html
