Any good math guys out there?
I have the following specs:
1. string spacing at nut: 1.5" (1 3/4" nut minus 1/8" each side from nut end to string slot)
2. string spacing at saddle: 2 3/8"
3. Scale length : 25.4"
How can I calculate fretboard width at the 12th fret?
This is pathetic. I used to do this stuff in my sleep. :-)
Thanks
Calculate fretboard width
Re: Calculate fretboard width
I always use the width of the strings at the saddle to determine the fourteenth fret width, but a lot of makers will use this width at the twelfth.
Bob
Bob
I started working on a similar problem this weekend. I'm NOT SURE of my answer yet. I'm going to draw it out and measure unlessdeadedith wrote:Any good math guys out there?
Thanks
Ken comes back with a known good formula.
Adding 1/8" to each side of the saddle if you want close to 1/8" from the string to the edge of the fretboard at the 12th fret
1 6/8" + (2 5/8 " - 1 6/8")/2
1 6/8" + (21/8" - 14/8")/2
1 6/8" + (7/8")/2
1 12/16" + 7/16"
1 19/16" or 2 3/16"
You have to make up one half of the distance in width in one half of the scale length.
I'm sure that Ken will be here in a minute to give you the CORRECT answer.
Here is the formula I use.
(((String spacing at saddle)-0)/1)*1= fretboard width at 12th fret.
To save you all from the math, the formula works out to:
String spacing at saddle= fretboard width at 12th fret.
I just measured a couple of guitars I own, and that does seem to check out.
Thanks guys.
Thanks guys.
deadedith wrote:I just measured a couple of guitars I own, and that does seem to check out.
Thanks guys.
So my formula worked then? GREAT!!!!!
