How to bind a headstock
Eric_K
Post by Eric_K » Tue Feb 14, 2012 10:57 am
How does one bind a headstock, especially around the sharply curved areas that approach the nut?
By hand?
Thanks,
Eric
Re: How to bind a headstock
Post by ken cierp » Tue Feb 14, 2012 11:15 am
I always thought this was a good strategy for plastic and fiber trim:
Eric_K
Post by Eric_K » Tue Feb 14, 2012 11:21 am
Ken:
Thanks! Looking at the photo, I believe that your tool could be used to cut the channels? Have you had success with that?
Eric
Post by ken cierp » Tue Feb 14, 2012 11:26 am
Honestly, I never tried to channel a head-stock with the hand held IA attachment, perhaps others will have input?
Post by Ray Ussery » Tue Feb 14, 2012 11:30 am
kencierp wrote:Honestly, I never tried to channel a head-stock with the hand held IA attachment, perhaps others will have input?
So then, what did you do it with? :0)
Post by ken cierp » Tue Feb 14, 2012 11:42 am
A regular router table and of course this tool:
http://www.kennethmichaelguitars.com/bi ... chine.html
Bob Matthews
Post by Bob Matthews » Tue Feb 14, 2012 4:26 pm
Have just bound this headstock for a ukulele that's nearly finished.
I use my laminate trimmer to rout the channel.
I then glue the purflings in with ca and then bend the bindings on a hot pipe until they fit the curves as close as possible.
I mitre the bindings and glue them in - also with ca.
My quick and dirty hot pipe is a 12" long piece of scaffolding tube clamped to the bench, I heat the exterior of the tube with a blow lamp until water sizzles and dances on the surface and then bend, the tube wall thickness is nearly 3/16", so the pipe holds its heat long enough to do most bends, or I reheat. Hope this helps.
Bob
