I could not find a better thread for this, so feel free to move it if its not in the right place.
I would like to sign my headstock with initials instead of cutting and inlaying MOP. I don't want a decal either. I would just like to put my initials at the top with some sort of paint pen and then just lacquer over it. I would like the paint to not dry too quickly so I can wipe it off if my first attempts don't come out as I want. After much practice on paper I think I have some decent looking initials.
Has anyone done anything like this? Is it a terrible idea? What is the best material to use to do this that won't react badly with the lacquer?
Thanks in advance!
Headstock Logo
Re: Headstock Logo
I'd think the safest way would be to fill and seal with lacquer chemicals, use an oil base paint pen since those solvent won't affect the lacquer and can be removed with naphtha, top coat the HS with a water borne product. $.02
Re: Headstock Logo
Thanks Ken! As always great advice. I am going to try it out on some test wood first.
My goal here is not to ruin my build at the 11th hour by having a terrible looking headstock by messing up either cutting the MOP or routing for the inlay. I can only get so far using a jeweler's saw and one small slip of the router is difficult to recover from. I have seen some terrible inlay jobs on otherwise great looking guitars.
In my research I came across MOP veneer sheets that appear to be pretty easy to work with. Has anyone tried using these? Have their been problems down the road with these coming off, chipping, or other problems?
Martin uses MOP only on their top models and some sort of raised decal or sticker on the rest of their headstocks. Anyone gone this route?
- johnnyg
Re: Headstock Logo
I've seen some cool results using water slip paper to make HS logos -- pretty simple process, color printer, then the image is sealed with water proof clear finish before the decal is applied to the surface. I am sure it requires additional coatings after application.
Re: Headstock Logo
I had a Martin-esque headstock logo made up for me by a lady in New Mexico who has made all kinds of r/c model aircraft graphics for me and other in the past. Turned out really nice, too. I suggest an inquiry to her. I supplied dimensions, the text I wanted, and asked that the look and feel of Martin's script be used, and the results were delightful. Callie Graphics.
Re: Headstock Logo
There are plenty of suppliers that make custom decals -- seems a bit pricey like two for $10
Re: Headstock Logo
I am currently talking with PrecisionPearl.com about cutting my MOP logos. They have also indicated they can set them in the headstock veneer if I like. I can either send them the veneer or they have rosewood and ebony on hand. I will post what their quote is when I get it. Right now they are working on the artwork for the logo. I expect some one time upfront costs for the artwork, creating the templates and an initial minimum run, but after that I can order one at a time.
It's still my intention to develop this skill but until then great looking headstocks is my priority.
- johnnyg
