Here's a headblock problem for you
Post by Dave Bagwill » Wed Apr 27, 2016 8:00 pm
I happen to have a friend's guitar in the shop that needs some work. However, it may be that there is no reason for me to continue.
The angle of the fretboard to the heel is like, 90*. That's right, there appears to be no angle at all.
DOA? The bridge is 3/8" tall already. The neck is off the body. I'm stumped. It hasn't been played in a very long time, duh.
Re: Here's a headblock problem for you
Post by John Parchem » Wed Apr 27, 2016 9:21 pm
Can you reset the neck? Is the neck bowed in as well?
Post by Dave Bagwill » Thu Apr 28, 2016 1:55 am
Actually, the neck block is 90* like in the attached graphics-heavy illustration :-)
Post by ken cierp » Thu Apr 28, 2016 9:37 am
Where does the finger board plane pass over the bridge? how high? Does the neck plane pitch up, nut toward the sound board or lean back?
What kind of guitar?
Post by Dave Bagwill » Thu Apr 28, 2016 10:02 am
finger board plane about 3/8" above bridge. I don't know what brand of guitar it is.
The fretboard to cheek angle is 88.7* !
Post by Tim Benware » Thu Apr 28, 2016 11:03 am
3/8" above the bridge? Sounds like multiple things going on. I wouldn't think the 90* angle would throw it that far off. How thick is the bridge?
Post by Dave Bagwill » Thu Apr 28, 2016 3:01 pm
I have another neck I'd like to use - has an 88.5* angle - when I position it with a fretboard taped on, the extended clearance above the bridge is less than I first thought - 1/8". The bridge itself is 3/8".
