Adjustable saddle routing jig
For my size 2 I wanted to make my own pyramid bridge. The hard part for me would be to get the saddle slot routed correctly. I also wanted to be able to make other styles as well so I made this jig based off of various designs found on the net. Trial run went well. Will work with either my laminate trimmer or my dremel.
- Upper base with slots cut for adjustable fence and stop blocks.
- image.jpeg (176.04 KiB) Viewed 1937 times
- Slot detail.
- image.jpeg (124.96 KiB) Viewed 1937 times
- Adjustable fence.
- image.jpeg (189.85 KiB) Viewed 1937 times
- Stop blocks with cut out for end clamps.
- image.jpeg (84.54 KiB) Viewed 1937 times
- image.jpeg (125.69 KiB) Viewed 1937 times
- Assembled jig.
- image.jpeg (178.72 KiB) Viewed 1937 times
- With bridge blank and router.
- image.jpeg (199.71 KiB) Viewed 1937 times
- Success.
- image.jpeg (201.96 KiB) Viewed 1937 times
JJ
Re: Adjustable saddle routing jig
Looks logical and straight-foward. Thanks.
John, is plunging the bit an issue?
(by the way, I have a link to something similar for cutting back-angled slots. Not trying to hijack John!
http://www.anzlf.com/viewtopic.php?f=24&t=1741)
So far no. I just tip the router into the slot with the length.Kevin in California wrote:John, is plunging the bit an issue?
JJ
