I've gotten to wondering what's wrong with using a strap pin in the endpin position? At first look, it seems as if doing so would avoid the potential problem of splitting the sides and end block if a conventional endpin-fitted guitar landed on the endpin when the instrument is dropped. Seems like a good place for a threaded fastener.
Thanks, folks.
endpin substitution
endpin substitution
Re: endpin substitution
You can get strap buttons from a variety of places in both wood and metal. They are easy to install. Basically the same button one would use the heel can be used on the end.
