Router question
Router question
Post by Dave Bagwill » Fri Sep 06, 2013 12:57 pm
Can a router be safely slowed down? How would one go about that?
Re: Router question
Post by ken cierp » Fri Sep 06, 2013 1:07 pm
These go on sale for about $15 or less
http://www.harborfreight.com/router-spe ... 43060.html
Usually you run the router as fast as possible -- tip speed rules! Slow down for larger bits over 3/4" Burrs work best running fast.
Re: Router question
Post by Kevin in California » Fri Sep 06, 2013 2:05 pm
I have that HF speed control. I use it on my RA Sander that doesn't have variable speed.
My understanding is that you DON'T want to use the speed control with a router that has a soft start motor, such as my Craftsman has.
My HF trim router does not soft start, so I can use the control with that.
Re: Router question
Post by Tim Benware » Fri Sep 06, 2013 2:09 pm
And as an aside, that is the controller I use to control the heat setting on my blanket for bending.
