Neck joint issue
MarkAndrew1
Neck joint issue
Post by MarkAndrew1 » Sat Aug 24, 2013 1:11 pm
I have the neck secured to the body and, as you can see,
it's protruding above the top. The channel is clear and center
line is good. Do I:
1. shave the back side of the tenon (without messing with
the set angle) to lower the neck flush to the top.
or
2. lengthen the holes in the neck block. There seems to be
be a small gap between the back of the mortoise where the
tenon meets it. So, this would drop it down enough to lower
the neck to the top.
Re: Neck joint issue
Post by John Parchem » Sat Aug 24, 2013 4:22 pm
As you suggested you can lengthen the holes to drop it in. If necessary you can shorten the tenon if you are hitting the back of the mortise. So basically a combination of both is OK if that is what it takes.
Post by Tim Benware » Sat Aug 24, 2013 7:20 pm
johnparchem wrote:As you suggested you can lengthen the holes to drop it in. If necessary you can shorten the tenon if you are hitting the back of the mortise. So basically a combination of both is OK if that is what it takes.
Yup.
Post by ken cierp » Sun Aug 25, 2013 9:41 am
I agree with Tim and John -- Plus I would create a little gap were the tenon butts up against the mortise just to make sure it does not interfer with the tilt (set) angle. Have you shaved the heel cheeks so only the perimeter is touching the body? The is one of the secrets to producing a super tight gapless joint.
MarkAndrew1
Post by MarkAndrew1 » Sun Aug 25, 2013 9:50 am
Thanks guys! I'm gonna get to work. I will post pics
after I'm done.
MarkAndrew1
Post by MarkAndrew1 » Mon Aug 26, 2013 3:55 pm
ken cierp wrote:I agree with Tim and John -- Plus I would create a little gap were the tenon butts up against the mortise just to make sure it does not interfer with the tilt (set) angle. Have you shaved the heel cheeks so only the perimeter is touching the body? The is one of the secrets to producing a super tight gapless joint.
Ken....Can I use a file to shave the heel cheeks? It seems like that
might be easier to control than sandpaper...
Post by ken cierp » Mon Aug 26, 2013 4:21 pm
6th photo down
http://kennethmichaelguitars.com/neckfitpart1.html
You should use a very sharp chisel -- I have used a Dremel with a 1/4" bit but suggest a lot of practice first. You wan to end up with about 3/32" that actually touches the body
