Stew Mac router bits or something cheaper?
MarkAndrew1
Post by MarkAndrew1 » Tue Jul 09, 2013 11:55 am
Hi,
i just picked up a Bosch router and I was looking
at the Stew Mac Standard set of 9 bits for $94.
Is this a good value or is there a cheaper set
somewhere else?
Re: Stew Mac router bits or something cheaper?
Post by ken cierp » Tue Jul 09, 2013 12:21 pm
Our KMG Binding Machine (its $198 with the router) uses one bit -- $6.00! $12 for Bam Carbide. Anyway There's no real reason to buy a bearing set -- purchase the bearings based on the need to match the binding etc.
MarkAndrew1
Post by MarkAndrew1 » Mon Jul 29, 2013 10:55 am
ken cierp wrote:Our KMG Binding Machine (its $198 with the router) uses one bit -- $6.00! $12 for Bam Carbide. Anyway There's no real reason to buy a bearing set -- purchase the bearings based on the need to match the binding etc.
Yeah, I'm new too all the router stuff. So, Ken, where do you get
the $6 and $12 bits from? I've seen some at Home Depot but not
that cheap. They also sell the bearings....
Post by ken cierp » Mon Jul 29, 2013 11:16 am
Our binding machine uses a single 1/4" straight bit, does not require a special cutter or bearings. These HSS are available everywhere (like Vermont brand Ace Hardware) for a few dollars, we prefer the carbide version from Bam Carbide which is currently $12.00. We get our inlay bits from "Drill Bit City" very good pricing on small down spiral bits. I have to admit dealing with Stew Mac while pricey is hassle free -- so on occassion we source to them.
MarkAndrew1
Post by MarkAndrew1 » Mon Jul 29, 2013 11:36 am
ken cierp wrote:Our binding machine uses a single 1/4" straight bit, does not require a special cutter or bearings. These HSS are available everywhere (like Vermont brand Ace Hardware) for a few dollars, we prefer the carbide version from Bam Carbide which is currently $12.00. We get our inlay bits from "Drill Bit City" very good pricing on small down spiral bits. I have to admit dealing with Stew Mac while pricey is hassle free -- so on occassion we source to them.
Great! I can use that for mortising as well right?
Post by ken cierp » Mon Jul 29, 2013 11:54 am
The Bam bits are bottom cutting and suitable for mortising -- you'll have to check the other brands I would guess yes.
MarkAndrew1
Post by MarkAndrew1 » Mon Jul 29, 2013 12:16 pm
ken cierp wrote:The Bam bits are bottom cutting and suitable for mortising -- you'll have to check the other brands I would guess yes.
Thank you!
