Backstrip: Routing or sandwich between back plates?
MarkAndrew1
Post by MarkAndrew1 » Tue May 14, 2013 12:53 pm
I read on another forum that some people sandwich their
backstrips between the 2 back plates rather than routing
it after.
Any opinions?
Re: Backstrip: Routing or sandwich between back plates?
Post by ken cierp » Tue May 14, 2013 1:17 pm
Depends on the inlay -- if it is thinner then .125" you have to route a channel. Other wise pinching it between the two halves is much easier -- the exception would be if the strip is very fragile, in that case a channel may work out best.
Post by Tim Benware » Tue May 14, 2013 2:39 pm
I sandwich mine but I only use Martin style zig-zag, checker and multi-color. I flood them with thin CA to strengthen them.
