Here again!
Re: Here again!
Hey Ray! Howdy, good to see you back. Sounds like you are doing much better??????
Re: Here again!
Hey Ray, Nice to hear from you again. Welcome back Texas boy.
Re: Here again!
Ray, as promised here's my tiny shop. It's the corner of my basement. Working around a water heater, furnace and a bathroom jutting on the end. I use an overhead shelf to store my mega mold and current in progress parts. Up between the joists I store my wood. Hope it gives you some ideas.
- Entrance.
- image.jpeg (171.26 KiB) Viewed 993 times
- Spindle sander. Fan/filter helps with dust (needs a cleaning!).
- image.jpeg (166.14 KiB) Viewed 993 times
- Main work area. 38" height helps for back fatigue. Assembly and finishing done here.
- image.jpeg (117.15 KiB) Viewed 993 times
- Clamp storage. Screws/bolts etc.
- image.jpeg (152.28 KiB) Viewed 993 times
- Drill press and belt sander. Storage underneath for bender.
- image.jpeg (159.79 KiB) Viewed 993 times
- HB workbench that I can pull out at an angle to use the end clamp (with my guitar body holder).
- image.jpeg (116.16 KiB) Viewed 993 times
- Flip table with table saw/router table, drum sander and band saw. Flip table and drum sander are on casters.
- image.jpeg (96.18 KiB) Viewed 993 times
- Overhead shelf and rafter storage.
- image.jpeg (75.91 KiB) Viewed 993 times
JJ
Re: Here again!
You've got a lot of stuff in there John, my workshop-in-the-garage is pretty much the same.
Re: Here again!
i would like to know a little bit more about the thickness sander you built. Are you using the table saw motor to power it? Is the design in your head or do you have some plans for it?
Thanks!
Thanks!
- johnnyg
Re: Here again!
I believe that plan was posted back here:i would like to know a little bit more about the thickness sander you built. Are you using the table saw motor to power it? Is the design in your head or do you have some plans for it?
Thanks!
http://acousticguitarconstructionforum. ... f=5&t=2571
Re: Here again!
Thanks Ken, i didn't realize it was the same plan. I am starting on it this weekend. I was intrigued by the use of the table saw. Is it just using the table as place to set it or is it somehow using the table saw motor.
- johnnyg
