KMG 000 First Build
Re: KMG 000 First Build
Started routing the back. Scary stuff.
- image.jpg (107.11 KiB) Viewed 492 times
JJ
The instructions mention that a few passes be made at a shallow height and depth then the final finish adjustments and cut -- I sure hope that's what you are doing
http://www.kennethmichaelguitars.com/bi ... ution.html
I practiced on scrap until I felt comfortable and the got to the depth and height I wanted. It came out well, however I will take shallow cuts first when I do the top.
- First side glued. Fitting the other side.
- image.jpg (137.11 KiB) Viewed 577 times
- Second side.
- image.jpg (139.32 KiB) Viewed 577 times
- Came out very nice in spite of myself.
- image.jpg (145.67 KiB) Viewed 577 times
JJ
Awesome!
One thing I've been meaning to add to the instructions is that it is better to have the channels a few .000 deep as opposed to the other way around. That way the binding will not get shaved down and look/be uneven varying in thickness after scraping and sanding.
Looking might fine indeed!
Cut out the rest of the neck mortise and test fitted the neck.
- Neck mortise.
- image.jpg (100.1 KiB) Viewed 564 times
- Test fit.
- image.jpg (131.01 KiB) Viewed 564 times
JJ
Just got back from a little r&r in Florida (with a little spring training action). Routed the top and installed bindings and purfling. It's not nearly as difficult as I originally thought. Scraped and sanded it down and very pleased. Started on the frets this evening. I had a decent size chip out one one fret but was able to super glue it back in and sand it out. Can't even see it.
- Top binding done.
- image.jpg (124.82 KiB) Viewed 539 times
- Very happy!
- image.jpg (80.38 KiB) Viewed 539 times
- Fretting
- image.jpg (84.23 KiB) Viewed 539 times
JJ
