A Manzanita Local Wood Parlor
Re: A Manzanita Local Wood Parlor
Post by Carl Dickinson » Wed Feb 11, 2026 10:05 pm
Slotting some fretboards. Since everything was out four were slotted, two 24.5" and two 24.75" scale.
Here's the setup.
I miss LMII.
Post by Carl Dickinson » Fri Feb 13, 2026 3:01 pm
Shaping the fretboard surface to a 20' radius. I start on the thickness drum sander with a jig with one edge raised with a glued on strip about 3/16" high covered with 80 grit sandpaper to keep the fretboard from sliding off. Sorry no pics of that process.
Then after cutting the taper on the fretboard, I sand it with the 20' block until all pencil marks on the fretboard are sanded off. I cheat by using a pneumatic inline sander that I've had for 50 years since building waterbed frames a long time ago.
Post by Kevin in California » Fri Feb 13, 2026 8:15 pm
now that is slick. never thought of attaching the radius block to a sander. I've got an old Rodac straight line sander I could try that with. Actually I think I have a smaller but it has a wide pad on it. I think it's German made from the 80's
Dude13
Post by Dude13 » Thu Feb 19, 2026 9:49 pm
What kind of glue do you use for gluing the BMB purfling to the binding Carl?
Andris Freimanis,
Kincardine, Ontario, Canada.
Post by Carl Dickinson » Fri Feb 20, 2026 11:41 pm
Thin CA. I used to use TB3 but Kevin pointed out the CA worked just as well in a shorter period of time.
Dude13
Post by Dude13 » Sat Feb 21, 2026 9:45 am
I also was thinking TB3, but if CA works for you then that’s what I’ll use.
Thanks.
Andris.
Andris Freimanis,
Post by Herman » Mon Feb 23, 2026 1:50 pm
My trick is Titebond Ultimate 3. Never looses while bending.
