Herman,Herman wrote:John, Drilling those bridgepinholes first and making the guitar around it. Isn't that scary? There is no room for corrections on the neckjoint and nutposition left.
The only way you can cheat a little is the size/form of the bridge and choosing the scalelength afterwards. Or do I overlook things?
That is mostly true, I can fudge the 14th fret up or down a mm or so without it becoming an obvious mistake, and I have about a mm to play with on the bridge with regard to saddle position (.5mm up or down from the ideal). The positioning of the saddle would require that I move the the nut position up or down to correspond with my fudging. No big deal as I have not made the neck yet. Next, I need to be careful when I glue on the transverse brace as the transverse brace tucks right up to the neck block extension and will help set the correct position of the top.
