This idea came from
http://www.sixgunguitars.com/clearance_notch_saw.html
I used to get frustrated with trying to cut the string clearance notches in a bridge. All I could think of was to use the smallest round diamond file that I had. Time consuming and the notch was tapered to macth the profile of the file.
I ran across this article a couple of months ago and built myself one. I already had everything I needed, and you probably do too. It works great for cutting the string clearance notch. It turns out, this handy little knife is good for lots of other things too. I just used it yesterday to cut the binding even with the dovetail in the neck block. As a matter of fact, I liked it so much that I just made another one using one of those mini hack saw blades, with finer teeth.
Anyway, I thought I'd share it since it's now one of those things that "I can't live without" and somebody else might find it useful too.
Joe
Bridge String Clearance Notch Saw
Re: Bridge String Clearance Notch Saw
I made mine from a jig saw blade. A little thicker and stiffer. Works good, I do need to put a handle on it though.
