So I was about to notch a brace and decided this might work. It works great and relieves a bit of anxiety (for me) as well. A cheap plastic holder with a hack saw blade; an extra washer to keep the blades parallel and 1/4" apart (I'm using 1/4" braces but the adaptation to 5/16" would be a snap); another hacksaw blade, a little tape.
You can cut right there on the spot instead of marking two lines and making two cuts; or you can make one line and transfer the brace to something like Ken's neat angle sawing jig and cut the slot in one cut. I will no doubt refine this but it works as is. Any ideas to improve it for the good of the realm?
This is a handy notching tool
- forum 005.jpg (151.76 KiB) Viewed 1000 times
- Cutting right on the spot.
- forum 004.jpg (169.46 KiB) Viewed 1000 times
- Just an overall view of things
- forum 007.jpg (122.13 KiB) Viewed 1000 times
- Poor pic - this is the brace (1/4" stick actually) up against Ken's angle cutter.
- forum 006.jpg (167.15 KiB) Viewed 1000 times
Re: This is a handy notching tool
I've thought of a few ways to make this - just any method to keep two blades 1/4" or 5/16" apart (outside measurement) and parallel, and also with only 1/2 brace height exposed, will do the trick.
I wonder if this would work for notching the kerfing/rim for brace ends? Adjust the exposed part of the blade to cut only as deep as you want?
So I've been practicing on scrap pieces of bracing. Here is the method I've come up with that has its advantages - no 'creeping up' on the correct depth or angle, no having to eyeball approximate angles (for those with good eyes that is not a problem, for me it is) and virtually just a one cut per brace and you're done, since the 2 blades are fixed and parallel and work together. . Like I said, for a geezer like me this makes it goof proof.
- Set the angle
- forum 001.jpg (99 KiB) Viewed 974 times
- Transfer angle to brace - only one scratch mark or line is needed.
- forum 002.jpg (105.16 KiB) Viewed 974 times
- Put a mark or pencil line at the 1/2 height of the brace. This Rocker tool is great for that and other things.
- forum 003.jpg (100.04 KiB) Viewed 974 times
- Line up the tool on the scratch/line you put on the top of the brace.
- forum 004.jpg (109.1 KiB) Viewed 974 times
- Turn the other brace over and transfer the angle.
- forum 005.jpg (106.39 KiB) Viewed 974 times
- Voila!
- forum6.jpg (106.45 KiB) Viewed 974 times
This is the tool - HF under $2 if I remember. You can just cut one blade in half, no real need to purchase a second blade, I just had one laying around.
- forum.jpg (167.95 KiB) Viewed 966 times
Thats pretty neat Dave, but that X-brace is not really going to work. Its a bit short.
I glue on extensions to get out towards the rim.
Not.
Not.
