I'm guiding a fella named Eric in building a kit here in my shop. We're having a ball, he's getting some skills and is doing a fine job. Here are a few pix and I'll try to follow up with more as he progresses. The back is gluing on right now.
He already has his next 3 projects planned out. This kit is one of Ken's experiential line which I've mentioned before.
Eric's first kit - KMG 00
- I usually use a vacuum bag but wanted Eric to know how to use conventional clamps. We did vacuum the back however.
- DSC00611.JPG (182.52 KiB) Viewed 1139 times
- He's never used a sharp chisel before and was pleasantly surprised by how enjoyable it was.
- DSC00612.JPG (193.67 KiB) Viewed 1139 times
- An exciting moment for us both
- DSC00613.JPG (163.76 KiB) Viewed 1139 times
Re: Eric's first kit - KMG 00
A couple more pix. If 'a couple' means 'three'.
- Checking an re-re-checking the top fit before gluing.
- DSC00614.JPG (178.58 KiB) Viewed 1138 times
- We seriously needed only a few bands because we spent serious time fitting the braces to the notches. But hey, the box of bands was right there, so..
- DSC00615.JPG (192.02 KiB) Viewed 1138 times
- Using the kmg binding channel system to trim the top overlap after gluing. Easy as pie.
- DSC00617.JPG (200.93 KiB) Viewed 1138 times
Looks like Eric is doing a great job. Very nice of you to help him get started.
George
George
We cut some bindings out of brazilian cherry, installed them, now it is clean up the body time. BTW we laminated together the BC at .045" to make .090" bindings and they just laid right into the channels we'd cut with the kmg cutter; we super glued them in. Eric is cleaning up the binding using a little shop-made tool that is good for that, and also great for cleaning out binding channels and other uses.
A good day in the shop.
Note that the bc does not show up well in the photo - it is actually a somewhat red wood (not as dark as bloodwood) under finish and sets off the walnut nicely.
- forum 002.jpg (277.3 KiB) Viewed 1089 times
- forum 003.jpg (253.97 KiB) Viewed 1089 times
- forum 004.jpg (262.7 KiB) Viewed 1089 times
Boy that looks nice and clean.
Looking really nice. Great combination.
Very nice. I have three guys who want me to help them build, but I don't have the space to do so. I wish I did.
