Would someone explain this?
Post by Dave Bagwill » Fri Jan 04, 2013 1:25 am
Maybe a diagram would help - but I've read somewhere about gluing together some non-1/4-sawn wood and ending up with quarter saw or something like that? I do NOT get it. I am also probably framing the question incorrectly. If you can read my mind - I'll take off the tinfoil hat for a few minutes - please help me on this.
bertoncini
Re: Would someone explain this?
Post by bertoncini » Fri Jan 04, 2013 2:02 am
You can take flatsawn lumber and cut neck profiles out of it and when you glue them up the grain will be vertical...magic...quartersawn. If you don't understand, I think I have a Maple blank like this in shop I can try to get a good picture for you.
Post by ken cierp » Fri Jan 04, 2013 4:49 am
Exactly -- all our laminated necks are made from flat sawn material, when you stand it on the narrow edge it is a vertical grain sandwich.
Post by TonyinNYC » Fri Jan 04, 2013 10:13 am
Mmmmm....sandwich...
Post by Dave Bagwill » Fri Jan 04, 2013 11:55 am
Dave if you find a minute sometime to shoot an explanatory pic it would really help. The visualizing thing has never been my strong suit which is, surprisingly, sandwiches. :-)
Thanks.
bertoncini
Post by bertoncini » Fri Jan 04, 2013 5:03 pm
Dave
Flatsawn 1.jpg (59.28 KiB) Viewed 971 times
Here is the profiles as they would have been cut from the flatsawn boord
Flatsawn 2.jpg (37.92 KiB) Viewed 971 times
Here is the flatsawn "sandwich"
Flatsawn 3.jpg (50.4 KiB) Viewed 971 times
And here is in proper position
Hope this helps...please forgive the sloppy work...very old stuff I have had here for very long time
Post by Dave Bagwill » Fri Jan 04, 2013 5:21 pm
I will study that, Dave. There are just some concepts that kick my butt. It looks like you've simply turned the sandwich on its side?
