Cheap Side Bending
Tom OBrien
Cheap Side Bending
Post by Tom OBrien » Fri Dec 28, 2012 5:10 pm
This is a picture of the side bending fixtures I make.
The only thing that's "expensive" is the heating blanket, and the cost of the heating blanket is reduced if you go to McMaster-Carr and purchase them for $93.05, rather than the $160 charged elsewhere. You will need to also purchase a rheostat, a thermometer that can measure up to about 500 degrees and have the ability to connect the two-wire leads from the blanket to a two or three prong plug (because that's the way they come from McMaster-Carr). http://www.mcmaster.com/#heat-blankets/=ksjtmg
The molds are simply scrap plywood or fiberboard boxes made in the shape of half of the guitar body outline. I cut holes at strategic points (at the tail, neck and waist) that accommodate the jaws of an Irwin clamp. The other end of the clamp jaw is placed on a piece of wood that has a simple locking mechanism to secure it to the clamp.
I also bought two 6x36 pieces of spring steel from McMaster-Carr to complete my side-bending sandwich. http://www.mcmaster.com/#standard-sprin ... ts/=ksjzb1
The downside is that this method takes some coordination and mindful preparation. It's easy to not get things right.
It is important to attach a piece of wood at the tail end of the mold that acts as a terminating point so you know you will get consistent bends every time and you will get your bends in the right place along a board that is only just so long. Remember to give yourself an inch to an inch and a half extra at each end – factor this into calculating where this terminating point should be.
Re: Cheap Side Bending
Post by ken cierp » Fri Dec 28, 2012 5:21 pm
Aluminum works just as good if not better than spring steel (why fight the back-up slat?) and Omega has the heat blankets for even less then McMaster Carr.
viewtopic.php?f=8&t=45
Tom your bender looks a lot like the ones used at the Whetstone Guitar Maker's School
viewtopic.php?f=8&t=104
I agree, keep it simple!
Tom OBrien
Post by Tom OBrien » Fri Dec 28, 2012 5:55 pm
Thanks for the lead on sourcing the heating blankets for an even better price.
Rienk Ayers
Post by Rienk Ayers » Mon Feb 18, 2013 2:13 pm
kencierp wrote:Aluminum works just as good if not better than spring steel (why fight the back-up slat?)
What are the recommendations for thickness of aluminum slats?
Post by ken cierp » Mon Feb 18, 2013 2:43 pm
We use .024" aluminum and .007" SS
Rienk Ayers
Post by Rienk Ayers » Mon Feb 18, 2013 2:59 pm
kencierp wrote:We use .024" aluminum and .007" SS
Do you recommend 6061, 5052, or just 2024?
Rienk Ayers
Post by Rienk Ayers » Mon Feb 18, 2013 3:02 pm
BTW, here's my favorite source for aluminum.
http://www.aircraftspruce.com/catalog/m ... 6061t6.php
