scarf joint location.
I did a practice cut on this 1" Pb. The line on right represents the nut.the line on left is 2" from that point. My tuners would be 2 3/4" from nut. Is this ok.
- 1218121747.jpg (121.61 KiB) Viewed 2063 times
Re: scarf joint location.
Here's a sure way to get it right --- this plan is almost identical the the fixture KMG uses
http://home.comcast.net/~kathymatsushit ... gplan.html
Thanks Ken. I am definately going to construct that jig. I cut that joint from cumpianos book but used a bandsaw. the instructions were pretty staight forward. It just seems the tuners should be closer to the nut compared to the my other guitars that I measured. And his measurements dont line up with the headstock measurements. so I thought maybe I missed something.
I made that jig and it works great.
I did finally make this jig. Pretty simple works great. Perfect cut !
- image.jpg (94.09 KiB) Viewed 1716 times
Hey, you work at my speed making jigs:)
I know I have thought about for a year and half. The first neck I made I free handed that cut but not any more
