End block wood
End block wood
Post by Dave Bagwill » Tue Dec 18, 2012 7:21 pm
Any reason why poplar would not work for the endblock, as long as the grain orientation is correct?
Re: End block wood
Post by Kevin in California » Tue Dec 18, 2012 7:24 pm
I can't see why it wouldn't work just fine. I've thought about it myself, and also making kerfing from it. Very inexpensive wood, and pretty stable
The only thing would be looks....but the end block is pretty much un lookable..:>)
Re: End block wood
Post by ken cierp » Tue Dec 18, 2012 11:21 pm
As long as the moisture content is at 6 or 7 % --- Thinking back, based on the size of your tree that blew down you should have enough wood for about 5 million tail blocks.
Re: End block wood
Post by Dave Bagwill » Wed Dec 19, 2012 12:04 am
Tailblocks 'R' Us.
This poplar however is a dry board I got at the HD.
Re: End block wood
Post by TonyinNYC » Wed Dec 19, 2012 11:40 am
I bought an aspen board a while back for another project that never took off. I have used it for tail blocks on two guitars. It is hard enough and light enough in my opinion. And the grain is the right direction, so why not?
Re: End block wood
Post by Herman » Sat Jan 05, 2013 10:56 am
A lightweight wood will do I guess, but the strapbuttonscrew will loosen sooner. Maybe a hardwooddowel there will do the job.
Re: End block wood
Post by TonyinNYC » Mon Jan 07, 2013 10:29 am
I had not thought of the button issue. I might switch from the aspen I have and use something harder.
