Bending pipe heated with 6x6 Omega blanket
Post by ken cierp » Thu Nov 22, 2012 11:05 am
I certainly admire the ingenuity of our members -- but I got to thinking this morning and it occurred to me that I had on hand an Omega heat blanket (6x4) which I was not using. This thing only cost a few dollars and is off the shelf -- and most importantly they are design for such applications. So in about a half an hour I fabricated an outer sleeve to fasten the blanket to an aluminum pipe. This pipe is about 2-3/4" OD. The thing gets to about 400 degrees so I'll hook it up to a timer and light dimmer and a ground lead. The pixs that follow are pretty much self explanatory.
Go4aRyd
Re: Bender heated with 6x4 Omega blanket
Post by Go4aRyd » Fri Nov 23, 2012 12:40 pm
Great idea, Ken. I've been thinking of this kind of application as well for bending small pieces of headstock/fretboard end bindings. Now I have more to think on..... ;) Thanks.
-dean
Re: Bending pipe heated with 6x4 Omega blanket
Post by Kevin in California » Mon Nov 26, 2012 10:39 am
Great way to use one of those little blankets. Still have to be careful not to burn oneself!!!
Post by TonyinNYC » Tue Nov 27, 2012 11:26 am
I recently used my 6"x6" blanket to bend some cocobolo bindings for the ukulele. Unfortunately, I did not set the temperature high enough and I broke the bindings. Runout was also a factor. I only set the temp to 275*F which is what I would have bent at in the machine. I neglected the fact that the wood is not in constant contact with the blanket when bending on a pipe. I will need to use this method again to touch up some wenge bindings for the all cedar OM. I bent the sides and bindings on two different bending forms and the difference in the waist curve is enough to cause major fit issues. I simply can not get the bindings to fit unless I adjust the waist bend. Anyway, it worked OK with the binding until I hit a bad section of runout and snapped the binding on the lower bout curve. I got the upper bout and waist bent for a concert ukulele. Th "easiest" bend turned out to be the toughest for me to do. I went with black plastic binding instead.
Post by Ray Ussery » Tue Aug 20, 2013 7:09 pm
Ken, Omega shows a 2.5W; 5W and a 10W I would assume your 4X6 is a 10 W unit? It's currently $33
http://www.omega.com/ppt/FindPN.html?se ... rchbyp=yes
Ray
Re: Bending pipe heated with 6x6 Omega blanket
Post by ken cierp » Tue Aug 20, 2013 8:53 pm
Actually that was a typo in the subject -- the blanket is 6x6 and yes it's 10 watt per sq. inch
Post by Ray Ussery » Tue Aug 20, 2013 11:27 pm
ken cierp wrote:Actually that was a typo in the subject -- the blanket is 6x6 and yes it's 10 watt per sq. inch
Ok...thanks,
Ray
