Is it possible that someone might walk me through the process of
(1) getting from a 1x3 'neck blank' to an uncarved neck with a peghead, heel, mortise&tenon joint prepared, and truss rod channel routed out, more or less ready to shape into a neck
and
(2) what to do, and what not to do, to use that 1x3 neck blank to make a laminated neck with contrasting center wood and veneers between the three (?) pieces.
Or point me to a photo essay that covers the topic?
Thanks very much
Fabricating a laminated neck blank
Re: Acoustic Guitar Neck Constructions - Laminated Type
Not too difficult, make sure the 1x3 is a full 1x3 not nominal. This is as good as any:
http://liutaiomottola.com/construction/NeckBlank.htm
Re: Fabricating a laminated neck blank
Thanks very much. This helps me visualize the process quite a bit.
