surface sanding
Spray booths -- Holding fixtures -- Work space
surface sanding
Post by peter havriluk » Sat Aug 04, 2012 1:47 pm
I've blocksanded a guitar for hours before and after filling with West Systems epoxy. Results were nice, but very timeconsuming. Since then for home use I've bought a Makita 5" random action orbital sander which did a beautiful job on some raised panel doors I was refinishing. But doors are thicker than guitars - - - is this random action sander usable on guitar tops and backs without risk to the guitar? If it is, how fine a grit can I work up to before no more good can come of continuing to sand? I realize that I've embedded some references to sandpaper grit and when to stop sanding, however it's done.
Thanks very much.
Re: surface sanding
Post by Dave Bagwill » Sat Aug 04, 2012 1:56 pm
The ROS is an excellent tool for sanding guitars. I usually use 220 or 320, others will have their preferences but yes, by all means use the ROS.
Re: surface sanding
Post by TonyinNYC » Sat Aug 04, 2012 8:30 pm
Ditto what Dave said on everything.
Ken Hundley
Re: surface sanding
Post by Ken Hundley » Sun Aug 05, 2012 10:29 pm
Use it to get close, then hand sand the rest of the way. RO sanders can get pretty aggressive pretty quickly. Don't ask.
- Stevie Ray Vaughan
