Drill press fence and angles - my weak spot
Post by Dave Bagwill » Wed Aug 01, 2012 3:30 pm
See hi-tech gigaflop-intensive graphic attached.
It's "funny" how simple things can trip "us" up :-) In other words, visualization is not my thing when it comes to angles and such.
I know when the answer comes it will be a "Duh" moment for me. So be it!
I used a lot of " " in this post, hope I don't run out...
Re: Drill press fence and angles - my weak spot
Post by ken cierp » Wed Aug 01, 2012 3:55 pm
Like a taper jib for a table saw you need to actually move the piece past the bit at an angle. The fence is merely the locator ---- so cut a piece of scrap the same angle as the line you drew, flip it over tape it to your blank. Now the blank will ride along the fence as if the line on your blank was parallel.
Post by Dave Bagwill » Wed Aug 01, 2012 3:59 pm
Ok, maybe by doing it I will understand. How I can be so stunningly brilliant in almost everything else and suck at this is beyond me. :-)
Post by TonyinNYC » Wed Aug 01, 2012 9:14 pm
It's a mystery Dave. You forgot sickeningly handsome by the way.
Post by Dave Bagwill » Wed Aug 01, 2012 9:21 pm
I'm way too humble to bring that up.
Post by TonyinNYC » Wed Aug 01, 2012 10:28 pm
Good thing I was around to mention it!
Post by Tim Benware » Wed Aug 01, 2012 11:25 pm
The heck with the angle, I wanna know how you drill those elliptical holes?!
