Hey all...
I made this simple jig this week to make my first bridge. Basically it sets the router up to do a slot at the right angle in a bridge blank. It worked for me, made from scrap material. First I start with a bridge blank, and then drill the pin holes using my template (which was copied from a Martin Style bridge). The template has a slot in it, but that was actually unnecessary. Then I bolt the bridge blank into my slotting jig at the low and high E string holes. That holds the blank down. Then I run the router back and forth, using a plunge router to take a deeper cut every pass until I'm at the depth I want. At the end I have a bridge blank that has a routed slot and holes drilled for the pins. I shaped my bridge by hand after that.
Tj
Saddle Slotting Jig
Saddle Slotting Jig
- Base of the jig without the rails attached. It's just a right angle with two holes drilled for the E-strings. Ignore the other holes, the wood was just scrap material.
- BridgeSlottingJig-1.JPG (57.02 KiB) Viewed 1746 times
- Backside of the jig - it's elevated with feet so I can bolt down the bridge blank. I use wing-nuts on the back side of the jig.
- BridgeSlottingJig-2.JPG (54.63 KiB) Viewed 1746 times
- A shot of the rails that the router base slides on.
- BridgeSlottingJig-3.JPG (74.26 KiB) Viewed 1746 times
Re: Saddle Slotting Jig
Continued...
- A side shot of what the rails look like. The stops are holding the two rails together...they stop the router at the right places on either side of the routed slot.
- BridgeSlottingJig-4.JPG (39.89 KiB) Viewed 1745 times
- The template I use to drill the holes in the bridge blank
- BridgeSlottingJig-5.JPG (48.97 KiB) Viewed 1745 times
- The assembled jig
- BridgeSlottingJig-6.JPG (79.69 KiB) Viewed 1745 times
And finally...
- The router against the closest stop.
- BridgeSlottingJig-7.JPG (82.66 KiB) Viewed 1745 times
- The router up against the far stop
- BridgeSlottingJig-8.JPG (85.04 KiB) Viewed 1745 times
Nice. Can it be adjusted for different types of bridges?
Mine really doesn't have any adjustment as you see it. But I'm sure you could rig it up with some knobs to loosen it, change angles, etc... I guess you could drill new holes to position at different angles...
Normally I wind up making a simple jig like this for one or two applications, and then see how I can make it more generalized and adaptable. So I can see re-making the jig in a guitar or two to have more flexibility. But so far it's working!
Here it is in operation
- Routing the slot...
- BridgeFabrication-1.JPG (93.63 KiB) Viewed 1734 times
- the bridge blank in the jig post-routing
- BridgeFabrication-2.JPG (82.29 KiB) Viewed 1734 times
- The final product from the jig
- BridgeFabrication-3.JPG (54.04 KiB) Viewed 1734 times
The finished bridge...
- FinishedBridge.JPG (67.19 KiB) Viewed 1708 times
