Did I ruin this top
Woodyok
Did I ruin this top
Post by Woodyok » Wed Apr 25, 2012 2:30 pm
Hi All,
I wasn't sure if this should be in Rosettes or tops...anyway. I routed for my first Rosette with the StewMac Dremel base and rosette jig. I wanted to have the rosette just proud of the top so I wouldn't have to scrape too much. I accomplished that but when I turned the top over, this is what I saw.
Rosette 1.jpg (62.68 KiB) Viewed 1504 times
Rosette inside 2.jpg (65.73 KiB) Viewed 1504 times
Is this top ruined?
Woody OKeefe
Prescott,Arizona
Re: Did I ruin this top
Post by ken cierp » Wed Apr 25, 2012 3:04 pm
I believe it can be salvaged if you use epoxy -- I think that will unify the rosette and the thin sound board material.
Post by Tim Benware » Wed Apr 25, 2012 3:12 pm
Good idea!
Woodyok
Post by Woodyok » Wed Apr 25, 2012 3:42 pm
Unfortunately Ken the rosette is glued in with white glue. Unless you mean spread some epoxy on the inside?
Woody OKeefe
Prescott,Arizona
Post by ken cierp » Wed Apr 25, 2012 4:21 pm
OK I did not realize it was glued already -- no problem -- instead of those little sound hole reinforcements make one that goes all the way around the hole about an inch in diameter, or even a rectangle the ID should be just slightly smaller then the sound hole. Many classicals have this arrangement.
Woodyok
Post by Woodyok » Wed Apr 25, 2012 6:39 pm
Thanks Ken,
I'll work on that. Great idea.
Woody OKeefe
Prescott,Arizona
Ken Hundley
Post by Ken Hundley » Wed Apr 25, 2012 10:35 pm
I agree, I was thinking to make a donut and glue on the inside surface, then lose the soundhole reinforcement braces.
- Stevie Ray Vaughan
