Kerfing gap at head and tail blocks
osgoor
Post by osgoor » Mon Mar 19, 2012 2:33 pm
I am reading the instructions and am very clear on how the kerfing is installed. No where did I see anything mentioned about if the kerfing should but up to the sides of the head and tail block or if there is any gap. Since nothing is mentioned I assume I should butt it up to the blocks, correct?
Re: Kerfing gap at head and tail blocks
Post by Dave Bagwill » Mon Mar 19, 2012 2:43 pm
There are some luthiers that intentionally leave a small gap, reasoning that the gap eliminates the possibility of a rattle or a squeak of the kerfing against the block.
I've always gone right up to the block and haven't had a problem. But a gap is not a big deal.
Post by ken cierp » Mon Mar 19, 2012 2:46 pm
Here's three of many pictures in the KMG manual and on the KMG website in the RR kerfing articles, all show it butted -- not sure why a gap makes any sense? So any glue joint is a potential squeak or rattle? -- I think not. A gap however would not degrade the structure.
osgoor
Post by osgoor » Mon Mar 19, 2012 5:48 pm
Thanks Ken. I did see the pictures but wanted to confirm
Post by ken cierp » Mon Mar 19, 2012 6:08 pm
Snugging up those tight fitting inside butt joints also give a chance to work on one's craftsmanship. There's some makers that really work extremely fine on the interior - inlay and all!
David L
Post by David L » Fri Mar 23, 2012 6:49 pm
I alwats butt mine!
David L
