Many makers today use neck-blocks with the mortise pre-machined -- the point to remember therefore is that the mortise itself has the true position points -- the outer edges of the block does not come into play. Here's how this is handled when assembling a KMG kit or KMG neck component package.
http://www.kennethmichaelguitars.com/KM ... embly.html
Rim assembly sequence and check points
