side template vs rectangle
Rick_A
Post by Rick_A » Fri Dec 29, 2023 8:10 pm
Hello all,
I notice that some people bend their sides as a rectangle and others cut the side as per a contour template prior to bending. It seems to me that once the side is cut into a profile, it might be difficult to keep it located precisely as you get the sandwich situated in the mold. Do we have strong opinions one way or another?
Many thanks!
-rick
Re: side template vs rectangle
Post by John Parchem » Fri Dec 29, 2023 8:53 pm
I hate sanding in the profile so I cut using a side profile before I bend. I am really careful to note and mark the center of the waist and keep it in the center. Just an extra few minutes making sure that the profiled side is in the correct position to bend saves many minutes. The more I build the closer I am to the final dimension. I started giving my self a mm or 2 plus enough for the top profile. Now I cut right on a pencil line of the profile. So about .5 mm margin. I only profile the back.
Rick_A
Post by Rick_A » Fri Dec 29, 2023 8:57 pm
Many thanks for the valuable info John.
Post by Herman » Sat Dec 30, 2023 5:25 am
Hi Rick,
FWIW: I do the same as John does. Sawing or planing the sides after bending is no fun, because they are so thin.
Post by Kevin in California » Sat Dec 30, 2023 10:51 am
I also pre profile before bending, then they are close and get done in the radius dish. I do this, then glue in kerfing, then back in the radius dish to bring down the kerfing flush with the sides.
Rick_A
Post by Rick_A » Sat Dec 30, 2023 2:14 pm
Thanks Kevin and Herman - I will proceed with profiling the sides!
Post by peter havriluk » Sat Dec 30, 2023 11:54 pm
+1 on Kevin's process. Life's tough enough!
