top and back joiner
gilles
top and back joiner
Post by gilles » Sat Feb 26, 2022 1:31 pm
Hello,
Newbie working on my first build.
In the process of making my jigs now. Here is a photo of my plate joining jig, and the end result.
Sitka top and Sapele back. OM outline on joiner pic is not mine. Was there when I bought the wood.
Small Jumbo outline on second photo is mine.
gilles
Re: top and back joiner
Post by gilles » Wed Mar 30, 2022 7:29 am
Guitar build update:
Neck blank before glue: center strip of Maple, 2 strips of Canarywood, 2 strips of Santos Rosewood and Mahogany on the outside.
Post by Herman » Thu Mar 31, 2022 10:40 am
Nice Gilles, Not too thick, not too thin. You are making a striking neck.
bftobin
Post by bftobin » Thu Mar 31, 2022 12:29 pm
Looking real good so far, well done. The only thing you may want to check is the weight of the neck. If your OM body is very light, you'll want a very light trussrod.
gilles
Post by gilles » Thu Mar 31, 2022 4:00 pm
bftobin wrote: Thu Mar 31, 2022 12:29 pm Looking real good so far, well done. The only thing you may want to check is the weight of the neck. If your OM body is very light, you'll want a very light trussrod.
Thanks. Good to know!
gilles
Post by gilles » Tue Apr 19, 2022 5:50 pm
I am trying to source some of my wood locally...
I found some perfectly quarter sawn cedar I could use as bracewood.
Is it ok to use cedar bracewood on a spruce top? Or is this a faux-pas?
Post by John Parchem » Tue Apr 19, 2022 5:59 pm
I have used cedar once. It is a good tone wood but a pain to work with. I had multiple braces split while carving them with a chisel. If I was very careful I am sure I could have avoided doing that but ... Spruce is the best brace wood for nearly any application where stiffness vs weight is a concern.
