Start it at 2:09 - he uses it on a neck
What do you think? $37 - worth it?
Re: What do you think? $37 - worth it?
Hey Dave, I bought one a few months ago. I have only used it a couple of times for non guitar stuff. I am pleased with the quality of the build. Whether or not it is worth it I think depends on what you will do with it. I do plan on using it to rough out necks and it seems like it will work well for that. If that were the only thing I bought it for, it still would probably be worth it. There are many ways to carve necks though as you are well aware.
I just skimmed a few videos of this sander in use. I'd have to learn to use a very soft touch, it sure cuts fast. But it looks like it could help roughing out a neck. But price is right and it's its own treat to learn to use new tools.
Enjoy!
Enjoy!
I picked up a set of these to go with it. Should help me be more of less aggressive depending on which grit I use.
Hmmm, I had copied an Amazon link which shows up here with both a picture and the link. This is what they are.
1/2 Inch X 18 Inch Sanding Belts, 4 each of 40/60/80/120 Grits, Blue Belt Sander Tool for Woodworking, Metal Polishing, Zirconia Sanding Belts (16 Pack)
