Fret bender
Fret bender
Post by Herman » Mon May 25, 2020 2:45 am
If you buy straight fretwire, you need to bend it some way to match the fretboard radius. For years I did it by hand. In supply stores they ask up to 150 bucks for a bender. I found that on the expensive side. So I googled for a bender and found one on aliexpress for 20. Taking a chance for the 20, I ordered one.
After 9 weeks it arrived and found out why it was so cheap: crappy product with a main wheel that was drilled out of centre and the bushings had a large slack. My first bend made all kinds of radii in one pass, but not the right one.
At work we have a lathe, so I took de darn thing apart, turned new bushings and centered the main wheel. After rebuilding it works fine, but to those who have not the acces to rebuilding tools: Think before buying. ;)
"If things are that cheap, it probably has a reason."
Re: Fret bender
Post by John Parchem » Mon May 25, 2020 11:09 am
Chinese manufacturers can do high quality work, if contracted to do so with quality control in place. However with quality control absent they sell a lot of products that look right but lack the functionality of the item they are often copying. Good that you disassembled it and made a working product.
Hans Mattes
Re: Fret bender
Post by Hans Mattes » Mon May 25, 2020 1:53 pm
For several years I've bought my fret wire from LMI. They ship it as a coil, about 10" in diameter. When I cut a piece off the coil, it has a curve that allows it to be pressed (not hammered) into a fretboard, resulting in a good fit. As ever, it's better to be lucky than smart.
Brennan
Re: Fret bender
Post by Brennan » Thu Mar 10, 2022 1:11 pm
I just received the Bendernator and it is awesome. Reasonably priced too.
https://www.guitarbuilderonline.com/fret-bender.html
Re: Fret bender
Post by Herman » Fri Mar 11, 2022 12:55 pm
That looks excellent. And the price is spot on.
Now I have functional bender, I don't need another , but otherwise I would go for this one.
Re: Fret bender
Post by Dave Bagwill » Fri Mar 11, 2022 10:37 pm
That does look like a good tool.
I do much as Hans does - buy the frets in a coil and press them into the slots. I do use a fret barber to make the pressing very easy and not back-bend the fb.
Works for me, but lots of ways to skin that cat.
