This time I used silvertip epoxy for the pore fill and sprayed post cat Royal lac. With my previous problem of sanding through I have changed my process such that the end of my pore fill the guitar is perfectly level; really a finished looking guitar. At that point it is really easy to spray and level a set of top finish coats. I used 8 coats over two days. After that finish cured (one week) I went ahead and did a Robbie O'Brien taught French Polish. I often go with the French polish right of the pad. THis time I waited almost a month and sanded and buffed out the top.
Here is what I ended up with. Striped ready to finish
Back and sides sprayed and leveled
Here is the French polish off the pad. THis is after my final spirting off session.
