curly cherry pore filler
Post by peter havriluk » Mon May 06, 2019 8:25 pm
I'm in the midst of building an all-cherry guitar. So far, so good. When finish time arrives, does cherry benefit from pore filler? I've used z-poxy finishing resin to good effect on other projects, including the cherry necks on those. I'll probably not mess with success and use the epoxy on the neck. But the body, I have no experience with curly cherry.
Thanks!
Re: curly cherry pore filler
Post by John Parchem » Tue May 07, 2019 12:17 am
I have used it but, I know it is small pore wood. You may be able to fill with finish. Applying zpoxy if it is already part of your process will not hurt.
Post by peter havriluk » Tue May 07, 2019 11:47 am
Thanks, John.
Post by Kevin in California » Tue May 07, 2019 12:22 pm
Peter, you should not need to pore fill cherry. It is like maple in that respect. When you start your finishing, spray your sealer, a couple of coats. Sand it back level and spray one more coat, then start your lacquer.....you will be good!
Post by peter havriluk » Tue May 07, 2019 5:44 pm
Sealer...rattle-can shellac? I've never used sealers: Bare wood, Z-poxy, lacquer, admire.
Suggestions will be appreciated. Thanks!
Post by John Parchem » Thu May 09, 2019 10:51 am
I would use a rattle can Vinyl Sealer on the wood then nitro. You can generally find it in the same brand as your rattle can nitro.
Post by peter havriluk » Thu May 09, 2019 3:38 pm
Thanks, John. I'll look.
