I have some offcuts from some over-length side material. Will using these as crossgrain reinforcement strips be worthwhile, or will I be better served making reinforcements from thicker lumber? My temptation is to strip the offcuts into 1/4" wide pieces and install one every couple of inches around the side. I've seen side reinforcements made from fabric soaked in glue to trapezoidal struts in Bourgeois guitars and a whole lot in between.
Thanks, folks.
side reinforcement strip dimensions
Re: side reinforcement strip dimensions
With your side material, used cross grain, you will be fine. It just needs to prevent cracking of the sides along the grain.
If a glued cloth will do the trick, then solid wood will do too.
Thanks, reinforcing the anti-cracking idea is always worth mentioning. I had another topic, which of course I relied on telepathy to communicate...cupped sides. This seems to show up often enough that I might encounter it myself. Any idea whether side reinforcements made of the side's offcuts are useful in negating cupping? I can easily laminate a couple of thicknesses together and get struts a whole lot stiffer if I need to do that.
I use the side cutoffs for mine. I cut them 1/2" wide and the are the side thickness (~ .075"). I place six on each side, centered over the back brace and the others centered between the end/tail block and brace. I like the symmetrical look it gives. I also chamfer the sides and ends of the reinforcement strips.
- 15 Side Reinforcements.jpg (227.28 KiB) Viewed 3745 times
