Glue strength
Glue strength
Post by ken cierp » Tue Dec 13, 2011 11:30 pm
This is very interesting - hot hide glue apparently is not a very good gap filling adhesive. Other interesting test results as well.
http://www.oldbrownglue.com/pdf/HowStro ... ue_FWW.pdf
Re: Glue strength
Post by Dave Bagwill » Fri Jan 20, 2012 4:28 pm
Really interesting. Why use epoxy for the x-joint when the titebond is better than/equal to the epoxy?
Re: Glue strength
Post by TonyinNYC » Fri Jan 20, 2012 4:37 pm
Because Epoxy will fill any gaps better.
I love using Titebond because it is simple to use and works great. I am thinking about HHG for things we might want to easily reverse for repairs though. Possibly the bridge and fretboard. I know Titebond is pretty easy to get to release, but it still leaves a lot of glue behind that you need to sand off. HHG would allow a clean bridge replacement if it were ever needed down the road.
I never glue my necks or fretboard extensions.
Re: Glue strength
Post by Dave Bagwill » Fri Jan 20, 2012 4:43 pm
Gaps? Are you nuts? We don't leave no stinkin' gaps. :-)
I've got some hhg granules here but still cannot find a compelling reason to use the stuff. And that's because I'm lazy, probably. Another thing to have to tend to. Short open time. Etc. But the easy clean-up does go in its favor.
BTW, do you use the epoxy, Tony? What kind?
Re: Glue strength
Post by TonyinNYC » Fri Jan 20, 2012 5:04 pm
Only for pore filling. I use z-poxy for that.
Ken Hundley
Re: Glue strength
Post by Ken Hundley » Sat Jan 21, 2012 12:02 am
One of the biggest benefits for HHG is that it is the only glue that actually pulls the joint tighter as it dries. The others remain in place, or expand, as in Gorilla Glue.
- Stevie Ray Vaughan
Re: Glue strength
Post by ken cierp » Sat Jan 21, 2012 12:45 am
Please expand this thought - I have never heard such a claim as HHG singularly having this characteristic, HHG has water just like Titebond, Elmer's etc. all catalyze with oxygen and draw the porous surfaces together via evaporation.
