You will see the pic attached, if I remember to attach it; it comes from the KMG 'manual' online.
I can't tell from the angle of the shot, but it looks like the bottom of the nut is a tad below the bottom of the fretboard - I think it's just the angle, but my question is - would it make any difference if the nut is a 'tad' below the fb bottom?
A student went too far in cutting the neck slot, and I did the same thing myself once, and it was truly a PITA to shim it up, use wood filler, whatever - probably should have just chalked it up to experience and carried on?
What do you think, you thinkers?
Nut depth
Re: Nut depth
New nut?
CA a shim to the nut and trim excess -- I've done this dozens of times.
Re: Nut depth
So,if the notch for the nut is too deep, shim with mahogany or whatever the neck is made of?
Re: Nut depth
Sure --- most agree its best to glue the shim to the nut, I suppose you could shim the slot but I'd think that would be mroe difficult.
Re: Nut depth
Very important to have the bottom of the slot perfectly flat to assure proper sound transmission.
Re: Nut depth
Any idea how Martin cuts that slot - is it with a fixture of some sort?
