Soundport construction
EricNC
Post by EricNC » Thu Jun 29, 2017 9:30 am
Hey Guys.I am new to the board and I'm guessing I may be on here allot..!!
Question - In this picture, what are the construction layers for a soundport like this? It doesn't look like layers of veneer. Is this contructed before its installed in the guitar or shaped in it?
Any thoughts would be awesome..THANKS
http://www.beauhannamguitars.com/publis ... ment54.jpg
http://www.dreamguitars.com/products/le ... ndport.jpg
Re: Soundport construction
Post by John Parchem » Thu Jun 29, 2017 10:17 am
The way I have made them and the way I have seen them made is that a reinforcement patch about the thickness of the sides is installed in the sound hole location before the guitar is closed. I have mostly seen the sound port routed after the guitar is closed. I do it after I bind the guitar to avoid a hole where my binding machine indexes the rims. The binding and purflings on the inside of the sound port are added after the hole is routed. You can see the joint to close the binding in the first picture offset slightly from the center of the back side.
Post by Tim Benware » Thu Jun 29, 2017 4:09 pm
I make a cross grain veneer patch of different colors, it adds strength to the soundport and enhances the look of the edge. As long as it is structurally sound, it's all really what is most pleasing to your eye.
EricNC
Post by EricNC » Fri Jun 30, 2017 8:27 am
http://www.everettguitars.com/soundports.html
This everett guitar is more what i am interested in. The second layer underneath the sound hole. This could be done on the top sound hole i guess. Is this made oversized and glued to the side like the veneers? and them shaped?
Thanks fellas
