An easy diy fret crowning tool
Re: An easy diy fret crowning tool
And you can add a handle to it as well. If you look to the upper left you'll see the one I made many years ago. I use it with 400 and 600 grit before moving on the the polishing papers. It works very well and is really handy.
- 108 Fret Leveling Tools.jpg (247.39 KiB) Viewed 700 times
I use a ball burr in a Dremel then tune the channel on a fret
http://www.kennethmichaelguitars.com/fretdressing.html
