How bad is this?
johnnyg
How bad is this?
Post by johnnyg » Mon Feb 20, 2017 4:47 pm
So I was merrily sanding away on this neck and it was looking good. Then I tacked the fretboard back on and saw I took a little too much off at the nut on the treble side. The pic exaggerates it but it's about .008".
Anything I can do here or have I worked hours only to have a baseball bat?
- johnnyg
Re: How bad is this?
Post by Tim Benware » Mon Feb 20, 2017 5:56 pm
Did you double check your measurements to be sure it was in fact too narrow? You could also just center the FB on the neck and there would be .004" on either side. y adjusting the string spacing on the nut you may not even notice the difference.
johnnyg
Post by johnnyg » Mon Feb 20, 2017 6:18 pm
I was in the final sanding stage so I don't have room to move the fretboard without throwing off the center line. I have an idea to make the bass side match and then adjust the taper of the FB to blend in. This would leave me with a 1 5/8 nut width. Is that going to be too narrow or will I still have enough left to play with string spacing?
- johnnyg
Post by ken cierp » Mon Feb 20, 2017 8:28 pm
No big deal -- just center the board and taper/blend the edge of the board leaving it desired width on the fret side. Plenty guitars have the FB blended into the neck. Matter of fact I think you will like the feel of the neck vs one with the common 90 degree edge.
Post by John Link » Tue Feb 21, 2017 1:18 pm
I agree with Ken's suggestion. The 90 degree angle works fine in architecture, but is over-rated when it comes to dealing with human anatomy.
johnnyg
Post by johnnyg » Tue Feb 21, 2017 1:55 pm
Thanks for the great advice! This is the route I will go. To make sure I fully understand this, do these steps sound right?
1. Shave the side of the neck to the same amount on both sides and the length of the neck.
2. Then taper the sides to meet the new neck width.
Should I glue on the fretboard prior to tapering? That seems reasonable to me.
- johnnyg
Post by ken cierp » Tue Feb 21, 2017 6:24 pm
The last thing you want to do is shave more material off the neck ---- all the shaving/blending is done to the fingerboard
