"Terz" as to basic body shape; the lower bout is only 14". Twelve frets to the body, long scale.
Going to try a couple of new things on this one, to be revealed later. So I know they work :-)
Spent a day or two re-forming a couple of molds, one for construction purposes and one for side-bending purposes.
I will be using thick walnut veneers, and laminating them with TB original, clamping them into the mold using the cauls and clamps that Bogdanovich advises.
To that end I purchased a 4x8x1/8 piece of tempered hardboard at HD, $12.98 and cut part of it into 32"x4.5" strips.
Then I thinned the strips on the drum sander - from 1/8" down to .090" or thereabouts.
Then I bent them on a pipe (190*) to get pretty good fit - it doesn't have to be perfect, as the material is pretty thin and the clamps will pull it to the form.
I've got 4 of those strips bent and clamped into the molds overnight.
TBC..
New project Terz 00-12 cutaway
- DSC01908.JPG (172.17 KiB) Viewed 1051 times
- DSC01909.JPG (197.17 KiB) Viewed 1051 times
- DSC01910.JPG (213.49 KiB) Viewed 1051 times
- DSC01911.JPG (200.77 KiB) Viewed 1051 times
Re: New project Terz 00-12 cutaway
Looks like a fun project. are you using the tall mold to laminate the sides or the construction mold I see with the clamps?
I'll be using the tall molds for bending/laminating the sides - doing two at once.
I'll also be bending/laminating the linings using the shorter molds.
I cut up a maple board into 16 strips - 4 each for 4 linings - the board was a 3/4"x2" x6' from HD - enough wood for 3-4 guitar's worth of linings and bindings. The thinnest my benchtop bandsaw would cut was .090", so I will use the drum sander to get them down to .045", which x4 will = .180" linings.
Some of the strips are on the cabinet to the left of the saw.
Later today - probably tomorrow actually - I will glue the strips together in a mold, then round the bottom edge with a 1/4" roundover bit in the router.
- DSC01912.JPG (134.66 KiB) Viewed 1014 times
I went ahead and built the lining mold per Bogdanovich's book. The last pic shows the almost completed mold - it needs a bit of cleaning up - but the cork is installed and everything fits well.
- I double-taped the one side of the outside mold to the lining mold and used that neat roto-plane with a bearing go get a nice clean cut.
- DSC01913.JPG (212.39 KiB) Viewed 1000 times
- DSC01914.JPG (178.9 KiB) Viewed 1000 times
- Using two layers of cork and a spacer the width of the linings. I will cut on that line and the spacing for the two halves of the mold will be correct.
- DSC01915.JPG (147.93 KiB) Viewed 1000 times
- DSC01916.JPG (171.62 KiB) Viewed 1000 times
- DSC01917.JPG (169.32 KiB) Viewed 1000 times
That looks pretty cool. Are you able to just press in the laminates or do you need to pre-bend them
Just pull the 4 pieces as a unit into the mold, and clamp away. I'll post a couple more pix a bit later today.
