With my curiosity up after seeing Mr. Bagwill's Newzouki build I read up on the Irish Bouzouki. I hadn't heard of it before. So knowing nothing about them I decided to build one. Plans based on Graham McDonald's book.
Riamh Aghaidh!
Irish Bouzouki
Irish Bouzouki
- IMG_6078.JPG (146.39 KiB) Viewed 1079 times
- IMG_6079.JPG (173.44 KiB) Viewed 1079 times
- Building the rosette
- IMG_6080.JPG (141.77 KiB) Viewed 1079 times
- Channel for the rosette free routed
- IMG_6081.JPG (137.2 KiB) Viewed 1079 times
- Routing the sound hole
- IMG_6082.JPG (134.97 KiB) Viewed 1079 times
- Shellac seal coat
- IMG_6083.JPG (126.79 KiB) Viewed 1079 times
JJ
Re: Irish Bouzouki
Very cool -- rosette free-hand routing?
Re: Irish Bouzouki
JJ -that looks real good and man, did you do that overnight or something? :-) Fast.
Re: Irish Bouzouki
Thanks guys. I suppose if this were more than a one time design I could of made templates and used guide bearings. But I just used my dremel and the StewMac base and crept up to the lines. I figured it would be easier to build the rosette with purfling separately and then rout the channel. I put the rosette together one night and then inlaid it the next. First time with redwood.
JJ
Re: Irish Bouzouki
A little more progress. Top and back are braced and the neck is glued up and truss rod slotted. First time with this style bracing. I'm going with a laminated neck of mahogany with a walnut/maple/walnut.
- IMG_6092.JPG (134.04 KiB) Viewed 1027 times
- IMG_6093.JPG (166.24 KiB) Viewed 1027 times
JJ
Re: Irish Bouzouki
It looks like you're following the plans in the book, good work.
Re: Irish Bouzouki
Nicely done! Amazingly clean craftsmanship! I love the picture of the top braces.
