How do I remove this?
Post by Dave Bagwill » Fri Sep 09, 2016 1:37 pm
An old neck I've had around - I want to use it on the 8-string - I reckon that metal piece is a locator but it is a b**** to try and remove.
Any ideas?
Re: How do I remove this?
Post by dave d » Fri Sep 09, 2016 1:44 pm
It looks like it would compress by using vise grips, and then pulled out. But you've probably tried that already...
The other thought I had would be to try using a 'damaged screw remover' bit.
Post by Dave Bagwill » Fri Sep 09, 2016 1:57 pm
Yeah the vice grips did not work - yet. I am tenacious however, in addition to being a chick magnet.
Post by Dave Bagwill » Fri Sep 09, 2016 2:07 pm
Got it - fretwire cutters pulled it out.
Post by dave d » Fri Sep 09, 2016 3:21 pm
A successful Friday then! Take the rest of the day off.
Post by Dave Bagwill » Fri Sep 09, 2016 3:42 pm
I'm retired, so each day is just another piece of bright-colored string in the rich tapestry that is me.
Post by Tim Benware » Fri Sep 09, 2016 4:48 pm
If you're worried about damage to the edge of your cutters use a pair of side cutters to remove them, that's what I do.
