A little bit of i.d. help please.
Post by Dave Bagwill » Fri Jul 22, 2016 5:22 pm
Just found these items together in a little bag in a dusty (redundant) corner - any idea if they belong together and if so what purpose they serve? There is no screw hole for the socket-head screw. The thicker shaft of the other tool does in fact slip into the female part of the other thingie.
Sorry to be so technical. :-)
Thanks
Re: A little bit of i.d. help please.
Post by Herman » Sat Jul 23, 2016 12:05 pm
Easy question: A rocket launching set.
Post by Dave Bagwill » Sat Jul 23, 2016 12:28 pm
That's IT!!! I've been tinkering and tinkering with this thing in the back yard and haven't been able to launch! Thank you Herman.
Expect incoming over your house in two hours!!
Post by dave d » Mon Jul 25, 2016 10:58 am
Perhaps you know this already, but the part formerly known as " female part of the other thingie" is a router collet. Looks like a 1/2" collet, so if you were going to use 1/2" router bits, you would replace the one that's currently on your router (probably for 1/4" bits) with this one.
It doesn't need an allen wrench to put it on. A regular box-end wrench tightens it.
I don't know what that other thing is that looks like a top, or why you'd put one into the router collet. The mystery continues...
Post by Dave Bagwill » Mon Jul 25, 2016 12:00 pm
Thanks dave d - I did not in fact know that that part was a router collet. Now I do, and I think that completes my task of knowing everything that can be known in the universe. Except what that other part is. :-)
Eric_K
Post by Eric_K » Mon Aug 15, 2016 4:13 pm
The other doohikie might be a centering cone for said router....... maybe
Post by Dave Bagwill » Mon Aug 15, 2016 5:02 pm
I will see if that works, thanks.
